MF 1130 Clutch Adjustment
I'm working on a MF 1130 that I recently bought that had the
clutch pedal stuck down. I took the cover off underneath and
the clutch is fully engaged(it will start and move in gear fine) I
realized the clutch linkage was slipping on the shaft that
comes out of transmission, I loosened bolt pulled pedal up
and tightened bolt, I'm only getting about a 1/4 inch of
movement on the bearing carrier inside when I push the clutch
all the way in, so can somebody tell me how to adjust this
properly or do I need to split it? I appreciate any help.
