Hi I am having a problem with the PTO section of the dual clutch on my MF 130, the first stage works fine and disengages the gear but when fully depressed the PTO does not fully disengage, it slows down a lot but does not stop, as a result when engaging the PTO when the tractor is running there is a slight rubbing/grind when its engaged. I have adjusted the pedal a bit and also done the three bolts on the clutch increasing the clearance to 75 thou following a thread on her about clutch adjustment but no difference the PTO still does not properly disengage. Does anyone have any ideas?
Many thanks
Many thanks
