MF 135 Carb Throttle Linkage
BigRed69
I purchased a new Zenith carburetor for my tractor and installed it last night, but I have one issue. The carb has the reversible throttle linkage and I had to reverse it on to the motor side. It came installed on the side facing away from the motor so the outside vs. the inside. The problem I have now is that there isn't much clearance, once I hook up the throttle, for the throttle to move freely without interfering with the side of the carb. Has anyone had this experience and what did you do?
I am looking for a good massey ferguson mechanic around Columbus, OH if anyone knows one.
Is the carb the exact same as what you are replacing? I had a problem similar to yours last year. Ordered a replacement carb for an MF35 and it was set up on the opposite side. After looking it over I decided there was just enough difference to create a problem so I returned it. Tried another vendor and received exactly what I needed.
