I am seeking suggestions, comments, recommendations, even questions on my 1972 MF 135 diesel tractor. Last summer while I was bushhoging the tractor blew a pin hole in the by pass hose from the water pump up to the thermostat housing. Hose was old so I replaced this hose. Few weeks later I was bus hogging again and this newly installed hose did the same thing, blew the by pass hose again. Installed all new hoses with a high quality hoses, which included a new by pass hose from the water pump to the thermostat housing. Kept a closer watch on the cooling system. It felt as though the thermostat was not opening up, the top of the radiator was getting to hot, couldn’t hardly touch it, upper radiator hoes was too hot, lower radiator hose was not hot or even warm to the touch. I removed and installed a new thermostat and reinstalled all the housing and hoses. Same issue. Then checked old thermostat in hot water, it was opening and closing properly. Went back in and removed thermostat,, for testing,, today there is not a thermostat in the thermostat housing, checked the radiator with a hose and made sure that the radiator was not stopped up and it is not, water flowed properly in and out of it, replaced the old water pump with a new water pump, without a thermostat the tractor seems to run properly, the top of the radiator stays warm, top radiator hose stays warm, bottom of the radiator is Luke warm and so is the bottom radiator hose. I’m starting to think that the antifreeze/coolant is not getting pumped through the lower block and through the head back in to the thermostat housing back to the radiator, I’m starting o think it is only getting pumped back through the by pass hose and over time of use the engine gets to hot and blows the by pass hose. How can I determine / see if the antifreeze/coolant is truly getting pumped from the radiator up through the water pump and through the lower block and into the head and back to the thermostat housing and back into the radiator?
