MF 135 fuel leak
Red Rex
I have a fuel leak on the bottom of the injection pump as shown in the photos. Is there an O ring that I can replace or crush washer? How involved is it?
It MIGHT be the banjo washers, 5936 332C. Might also be the hydraulic head O ring, if so the wise thing to do is have the complete pump re-sealed and tested. I have an MF 180 pump in now for leak trouble too..
(quoted from post at 13:53:03 06/25/20) The leak is coming from where that bolt goes through the fitting into the pump
It may look that way, but it could be hydraulic head o-ring as Dieseltech said, had that happen to me once, and new banjo washers didn't fix it! Now whenever I see one leaking like that I reseal the pump, the o-ring is more likely to fail than the banjo washers.
Thanks for all the replies!
As I look closer at the pictures I can see a drop of fuel on the far left hand side. O ring replacement is going to be required.
Will I have to remove the pump to do it?
I have rebuilt carbs and engines but never anything diesel
