SkyePN
Work continues, next is fixing the gauges that don't work.
Gas gauge - can I ground or supply 12v to a terminal to check if the needle works? Looks like the pink wire should be connected to terminal 4 on the voltage regulator, what's that supplying?
Gas tank sender - check resistance range?
Ammeter - doesn't work, going to clean up the terminals and check with multimeter
My light switch is just on-off, not sure if that's original and haven't checked if the gauges have lights or actually light up.
It looks like the gauge lights all run off the inverter, what voltage (dc?) is the inverter supplying?
