My MF-135 with pressure control....
Hydraulic arms drop in 1 minute when engine is turned off. There is a light jerking when engine is running. If I place the diverter valve (on top cover near the seat) to aux position the arms take one hour to drop...then there is no problem with the cylinder.
The stand pipe has a "T"...I changed the top end and the lower end "O" rings with teflon spacers on the stand pipe. The side tube from the "T" goes (I think) to the pressure control valve. What type of seal or "O" ring is used on the tube that connect to the pressure control valve I suspect that there is a light leak from there.
Thanks in advance
Bart
Thanks in advance
Bart
