MF 135 PTO SEAL
Story
Noticed hydraulic leak at PTO shaft on MF 135, wondering how difficult it is to change out the PTO shaft seal. Thanks
(1) Drain oil from Rear End/Transmission/Hydraulic section of Tractor:
(OR)
(2) Place tractor with front end slopping down:
(OR)
(3) Back Tractor up RAMPS so as front end is low:
I've backed Tractor up RAMPS so as REAR TIRES were 8" above shop floor:
NOTE CAP SCREWS in PICTURE that have been removed:
PULL PTO ASSEMBLY from housing.
Inspect bearing assembly,oil seal and replace as per required.When an OIL SEAL shows signs of leakage, the bearing can be faulty:
Bob...
To add a little to what Bob has said;
The biggest problem that you are likely to encounter is pulling the shaft out of the tractor. Although only held by the grip of an O ring it is likely to require some assistance. You can either fit the end of an implement PTO shaft to the tractor Pto shaft or insert a 5/16 bolt in the cross-drilling in the end of the shaft. Use a pry-bar with the pivot point close to the PTO shaft with suitable packing to lever the shaft rearwards.
Many PTO shaft oil leaks are caused by grass/hay getting caught in the seal. This prevents it seating fully. The only answer is to replace the seal. The seal can be removed using a suitable piece of tube or large socket. Refitment can be done in a large vice. When refitting the shaft ensure that it is straight and fully home. Smear the preferably new O ring with grease and tap in gently with the handle of a hammer. Replace the plate screws and oil.
DavidP, South Wales
