MY 135 8 speed has always had a slight wobble, but since I took the loader off the wheel shimmy at speed got quite bad. The drop arms moved quite a bit with no movement in the steering wheel.
I replaced the drag link ball joints acouple of years and there is no play in the linkage. With the front end jacked up I adjusted the toe-in to so that with play it varied between 1/4" and none ( 1/8" ).
With the links removed and one arm fixed I could move the other one 5mm and the steering wheel 10 cm at the edge.
I hand tightened the top nut about half a turn and now with the steering box on the workbench the play is slightly less. There is some wear on the teeth of the shafts and the bushes show some wear.
I assume it's the shafts that need replacing, but if so, can I also replace the bushes without a reamer?
Also while dismantling I was looking for a ball bearing, shims, peg and tab washer on the left side , but only found the peg as in the photo. If a ball bearing is inserted the peg sticks out too far so I assume this is a modifiction but I would still expect a tab washer?
Any advice welcome. Without experience or a new part to compare with, the term "check for wear" is not always so easy.
Mike
Mike
