Mf 135 valve clearances
Hi all.
I have a massey ferguson 135 with the 3 cyl perkins ad3.152 engine in it and i need to adjust my valves, but the book has me a little baffled.
The book says to get the TDC line in centre of flywheel inspection hole and check numbers 1,2,3 & 5 ? then rotate the flywheel 360 degrees and check numbers 4 & 6.
The first issue is where is the said flywheel inspection port cover?? I think i have found it at the left of the tractor (when sat on it) in the plate that bolts the engine to the gearbox. It this correct??
The other prolem is how do i know which cylinder tdc i am at?? 1 2 or 3.
Finaly if i rotate the flywheel 360 degrees surely i will be back at the tdc mark agian, so nothing will have changed?? Or will a diffrent cylinder be at tdc??
Thanks for any help,
Tom
About the TDC mark, that mark always refers to the #1 cylinder. Each time the engine is turned through 360*, that mark will come around, and #1 cylinder will be at TDC.
Where it gets confusing, the cam turns at 1/2 the speed of the crank, so every other time #1 is at TDC, the lifters will either be at the beginning of the power stroke, or they will be in overlap, between the exhaust stroke and the intake stroke.
There are several methods of turning the engine to a certain position and setting certain valves. I have always found these methods to be confusing (but then I am easily confused).
It is essential that the lifter be on the "base circle" of the cam when the lash is set. At each end of the base circle there are "quieting ramps" that ease the lash out before the real opening action happens, and ease the valve closed without slamming. Not being able to see the cam position, it is too easy to assume the cam is in the right position, but in reality it is in the quieting range.
The method I have always used, and it is more time consuming, but I feel is a more reliable method, is to slowly turn the engine through with the feeler gauge between the rocker and the valve while finding the loosest point. It may take some turning back and forth, and the lash will likely change when locking down the jamb nut, but taking your time, getting it right is the goal.
I also like to start it up and listen before putting the cover back on, just to be sure.
Cam Profile
Hello Apprentice Tractor Fixer,
Like dieseltech said. With a valve open on a cylinder, adjust the other.
.012 cold. Would not worry about checking them hot. There is no specs for hot that I know of. Firing order is 123, so start at #1 cylinder,
Guido.
