MF 150 wheel torque
lurp66
Would anyone happen to know the torque on the rear wheels of a MF 150? 9/16 wheel studs & 1 1/16 lug nut. Thanks
if you are using classic view to read posts
on the left side of the page has a number of clickable links
in the research & info section there is a torque values listing
I would assume those bolts would be grade 8's
if you're using modern view almost at the top of the page in the red box you will see classic view click on it then scroll down the menu on the left to get there
it'll give you a base starting point
I've never torqued wheel studs on anything but front wheel drive cars with disc brakes
just tightened them with a long bar 3' swivel I call a johnson bar
main thing is to evenly tighten them
never had one fall off
