MF 165 brakes
steve stokes
Hi
When Ileave MF165 standing for a couple of weeks
righthand side wheel locks up ihave to jump it backwards and forwards to unlock any ideas on how to fix problem.(brakes sticking)
Many thanks Steve Stokes
Are you saying that you leave the tractor with the right brake engaged? If so, don't. Leave it in gear or chock the wheels to keep it from rolling away. :-)
Sound like the balls on the dry brakes are dirty/rusty and are seizing up at first use until they get used a few times. The only cure I know is to pull the trumpet and clean/replace the balls and make sure the ramps for the balls are clean and dry.[b:654c4848f0] No Oil![/b:654c4848f0]. When I did mine, I used some powdered graphite on the balls/ramps and have had no problem since. While your in there you might consider replacing the brake discs and springs too.
If you've not been into the brakes, the I&T MF-27 manual can get you into and out of them with a little mechanical knowledge and basic tools. It is heavy work though and you need some way to lift and hold the trumpet when it's removed.
Good luck.
Steve
