MF 175 clutch
cfrieda
I am replaceing the entire clutch assembly and i have forgot how the clutch plate that faces the flywheel was installed. The clutch plate has a flat side and the other side is extended out. Which direction does the extended side go? to the flywheel or the pressure plate?
Thank You
extended side faces away from flywheel, if you try it the other way it will hit the flywheel before the lining makes contacts
