MF 200 bulldozer
pbocco
I'm working on a MF 200 dozer. We've changed most of the filters and done a lot of basic "freeing up" of seized up parts and levers. we adjusted everything by the book, put on a new hyd pump . The dozer starts up good and the 6-way blade works as it should.
I need to find the inner filter (trans) so we can change that one also. The problem is that it only goes in reverse . In forward it seems like it wants to but doesn't. there's 2 valves that I think I need to replace (hi pressure and a low pressure valve)
Also,,,can I replace the tracks with another set of tracks (from a different manufacturer) as long as the measurements match up ?
So...I need some advice and possibly a source for the parts.
Thanks in advance
