MF 200 loader
Kalamazoo
Anyone have a MF200 loader? Just got one but its missing the dipstick. Could you measure your dipstick so I can determine the correct oil level?
(quoted from post at 11:33:10 09/11/23) My 200b had a Perkins motor so you may be able to match one that way. Lots of Perkins plants out there.
I believe he is looking for the loader hydraulic oil dipstick, that hangs inside the frame post on the right side of a MF 200 loader attachment, from the vent on a length of chain; not the tractor engine dipstick.
Kalamazoo,
I think some had a pipe plug, about halfway up that right post, which was the oil level, don't remember if it was on the inside or outside of the post. If yours has a plug like that in one side of that side post, you can check the level there. If you don't get a measurement from someone, I suggest making one. If I didn't have a dipstick, I would figure out where 2-3inches over halfway up that post was and measure from the vent plug down using that as the full level, to make a dipstick.
You might get a better answer for this if you post your request on the Massey Harris & Massey Ferguson Forum.
The full level on the dipstick of our model 32 is approximatelty 17 down from bottom of the breather. Your 200 should be similar because the frames are the same.
