MF 202 Filter Recommendations
miangus
My 202 recently sheared the key in the front hydraulic pump while my son was using it. I ended up pulling the pump and replacing the key and it appears to be ok. Troubleshooting the issue, he removed the filter next to the pump, and he said it looked pretty bad. Looking for the correct filter I found advice that said the old sock filter is obsolete and the recommended replacement is the same as the filter used in the gas engine for the oil filter a Wix 51010. Can one of the experts on this form confirm this, it just seems odd. Thanks all.
