Mf 204 hydraulic issues
So first time on here posting a question I
have a mf 204 with loader and hoe
hydraulics are real weak the filter is
trashed and fluid is all milk where can I
find a new hydraulic filter I havent found
one that looks anything like mine it's a
wire basket with what looks like a spool of
yarn inside and what can I use to
completely flush the system
Sounds like the same issue covered here recently on a 202. This may have your answer on the screen and filter. https://forums.yesterdaystractors.com/viewtopic.php?t=1390339. Your dealer should be able to help you.
You have a number of cylinders and hoses which will hold the contaminated oil and short of disassembling the entire system and flushing individual components; changing the oil in the system, several times if needed, is the common method to flush them. Drain all the oil you can from it. Refill with clean oil and run it. If it is still bad repeat. Just my thoughts, others will have more.
If you start the tractor and fully extend all the cylinders then shut it off and drain the system you will get most of the oil out. After it has drained for a while lower the bucket and retract the tilt cylinder. That should remove most but not all oil left in the cylinders. You may still need to drain and refill again to get all the watery oil out.
