MF 210 fuel sediment bowl replacement?
Hello all,
I've had a MF210 for a good while, and have lost the Sediment bowl,
took it off and flushed the tank a while back, and misplaced the bowl
the internet is not helping me much today in finding a replacement,
MF-210, 2WD, Diesel,
it's small, like a shot glass,
not sure if they are interchangeable with other models
Thanks in Advance
If you are talking about just the glass bowl, measure it carefully and go visit eBay (assuming this site doesn't sell one). I did this a month or two ago and there are a lot of used and NOS glass sediment bowls to choose from. But you may have to converse with the seller to make sure they have what you need. Even with good measurements, I had to rebuild the wire bale to make one fit correctly. If you have more problems finding one, send me the outside diameter of the gasket space, and the length from the gasket surface to the top of the tightener on the wire bail. I've looked at so many of them I might be able to help out. steve
Thanks,
another member sent me a message with some part numbers, and I think I have found the right one on ebay,
will update next week when it arrives
Thanks to all for your help, I was able to locate a bowl, and have managed to get it running,, some,
still having fuel supply issues mostly due to crud in the tank, that I had thought I had removed,
will remove the entire bowl assy from the bottom of the tank and flush it again, that should solve the stoppages
