MF 231S STARTER QUESTION
Allen L
The starter on my MF 231S has been clicking for some time and now no click. I am assuming the cylindrical piece on top of starter is a solernoid. Do you think it is the solernoid or do I need to buy complete starter?
Thank you for your thoughts and comments. Allen
Hi, a clicking noise from the starter is normally a sign that the contacts in the front end of the solenoid are burnt. Is this a UK-made tractor? There are 3 possible options depending on the make of starter: complete new unit, new solenoid (should cure the problem) or a solenoid end cap, normally one or two soldered wires to undo to change it.
DavidP, South Wales
Thank you David! My tractor has a label made in Turkey as I recall. I think I will try the Solernoid from E Bay, Is it difficult to install?
Hi, not sure which starter is fitted to the Turkish produced tractors. You may however have a UK made engine installed. If the engine serial number starts 152UA then it is made in the UK and likely to be a Lucas type. Typically the solenoid is retained by two nuts or screws. Remove the starter and remove the heavy cable going to the barrel of the starter. Withdraw the solenoid. It may leave the plunger in place. Note how it is attached before removal. Pull the plunger forwards (as if fitted to the tractor) and lift at the same time. There should be a make and manufacturer's part number on the body. Confirm the one you need with your supplier.
DavidP
I had similar issue with MF165 where the solenoid would click when trying to start, it could click once or 10 times before it would engage the starter. Having checked a number of different forums I discovered this is a common problem with older diesels. There is not enough voltage getting to the solenoid to throw it and engage starter motor. There is a simple fix for it by adding a low voltage relay. I bought one of these
https://www.amazon.co.uk/gp/product/B07XDRNZ7M/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Basically you place this between the existing wire into solenoid and the solenoid itself.
I fitted mine next to the ignition switch but you could fit it next to starter either. The colours of the cables may vary slightly depending on the relay you buy, but circuit numbers should be consistent.
Red (30) goes 12v power source, black(85) to earth, white(86) connects to wire that normally goes into solenoid, blue/purple(87) connects into the solenoid.
I have included link to other forum where I found the solution (#18)
Fix starter/solenoid click. Get to start engine first time
David, would appreciate your expertise in diagnosing starter noise/trouble starting issue on a MF 265 Perkins USA or UK made?
Its S #9a241526 with a sizable Delco starter.
After I had it completely rebuilt by a starter shop and know the battery is 100%, it has developed a starting problem where when hitting the switch it sometimes starts up immediately, but most time there is a sluggish grinding sound and after several separate tries the starter will start perfectly.
I am suspecting a bad Bendix. I suspect the starter shop will claim they installed a new bendix (am concerned that its a no good Chinese part they used).
Any idea of the problem?
