MF-240-S Starter
newtothis
This message is a reply to an archived post by fbh44 on January 15, 2020 at 10:06:07.
The original subject was "MF240S Starter".
I had similar issue with MF165 where the solenoid would click when trying to start, it could click once or 10 times before it would engage the starter. Having checked a number of different forums I discovered this is a common problem with older diesels across multiple makes/models. There is not enough voltage getting to the solenoid to throw it and engage starter motor. There is a simple fix for it by adding a low voltage relay. I bought one of these
https://www.amazon.co.uk/gp/product/B07XDRNZ7M/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 or this
https://www.amazon.com/gp/product/B07X1R18QS?pf_rd_r=KR1P8SH13BNWS6PT63Z2&pf_rd_p=6fc81c8c-2a38-41c6-a68a-f78c79e7253f
Basically you place relay between the existing wire into the solenoid and the solenoid itself.
I fitted mine next to the ignition switch but you could fit it next to starter either. The colours of the cables may vary slightly depending on the relay you buy, but circuit numbers should be consistent.
Red (30) goes 12v power source, black(85) to earth, white(86) connects to wire that normally goes into solenoid, blue/purple(87) connects into the solenoid.
I have included link to other forum where I found the solution (#18)
Fix starter/solenoid click. Get to start engine first time
