65plymouth
Need a bit of help. Posted recently about a 255 that I recently acquired. I was going to send it back to the dealer that sold it to me, but decided I am going to keep it after a bit of negotiation.
Long story short....this thing has a lot of hydraulic leaks. Main sources of leaks are the external filter housing, the rear remotes, and every single connection where lines meet the valve body. The tractor came with one set of rear remotes from the factory.
My questions....How big of a job it it to tear into the filter housing, lines, and valve body to fix these leaks? Would I be better off replacing the hard lines with regular hydraulic lines. Seems that any time those hard line get bumped, they start leaking. Other than lines and a replacement filter, what other parts do I might I need. Are there replacement valve bodies available if I find mine is bad or the inlets are stripped?
