grfen
Pto does not seem to want to shut off, just keeps on spinning, is there an adjustment or some other fix i should be looking for? Thanks in advance!
From the sounds of it I would say you have the independent PTO with hydraulic clutch pack. With that system the clutch pack can get wore and need rebuilt. Typically if you put an implement on there that is just enough pressure to keep it from spinning (sometimes even just grabbing it with your hand is enough to stop it but please be extremely careful trying that). If it is extremely wore it may not work at all even when in the engaged position. To fix top cover at least needs to come off. I'm thinking the transmission and pumps need to come out too to get to it but I'd have to check the book. If it stops with an implement on and still works in the engaged position I would not worry about fixing it yet.
I agree with acadam20, And if the pto will not stop with a light load, then its the pto brake that needs replacing. The brake should come on when power is cut. Fixing it requires internal repair. The brake wears out faster if the tractor is not idled before pto is shut off.
