I have a MF 2675 that all gauges on the console including the radio do not work. I was told of a oil pressure sending unit that if it fails all power to the console will be lost? Anyone heard of this I need to buy a manual for this tractor but dont know which one is the best
Diesel Masseys that Ive worked on have a switch built into the oil pressure gage. In Theory what it does is keep the battery from running down if there isn't any oil pressure. IE when the motor is off.
I have made other arrangements by installing a battery cut off switch between the hot side and my gages. I keep my car keys clipped to the same key so I can't leave without taking the switch key out. I just replace the original oil gage with a 10 dollar aftermarket and bypass the problem switch. The new ones even come with a little lite inside. Just put one in my old Suburban cause I don't trust the original one in the dash.
OldHH
I am not a great mechanic. I do have an extra
lightly used manual(operators)reas.There shows an
instruments fuse-10 amp in upper cab and an audio
5 amp if that helps. Chuck
This sound like a relay under the dash that is actavated by the three post oil preasure switch on the right side of the block.Remove the four screws that hold the fiber glass cowling over the dash and remove the cowling.There might be a fuse for this also.Fuses for the radio and heater fan are behind the dome lite. Been 12 years since I seen one.
