MF 2705 dash warning lights
Found that transmission/hydraulic oil was dirty. Jerky steering and 3-point. Changed filters and works like it should. But have found that I dont have many warning lights working on the dash. Only ones I'm pretty sure of are the oil pressure warning light (comes on with key) and the coolant level warning light.
Cant get a light for the transmission oil filter warning light. Can get a slight noise when the wire is grounded. Does it have a buzzer as well as a light?
Several wires are just hanging. One lit the dash light for hydraulic oil temperature. But dont know where sensor is. I have difficulty telling much from the parts book. I dont know where the sensors are located for many of the other dash warning lights.
Any help would be appreciated
Do you have the correct Massey Ferguson Service Manual (1448637) and Operator's Manuals for it? One of them should have the wiring diagrams which are likely going to be needed to track at least some of your problems down. If you have them, take and post some pictures of the wiring diagrams perhaps someone can help you with it.
The 2000 series models used that brown color ribbon under the dash and it goes into a large plug on the right side under the fuel guage if I remember correctly. They were a big problem for connections. After you check continuity in each bulb, you should also check that plug. It reminds me of an old school computer cable but it's very low energy current. Seems the bulbs are the typical 194's with the wedge style ends.
