MF-35 3-Point
doehmke
The three point hitch on my MF-35 raises when there’s no implement hooked up. But cannot raise an implement. Just raising and lowering the empty arms causes oil to come out the relief valves on the top cover near the oem 2-lever control valve. I’ve read the shop manual, but don’t quite understand what to check in this case.
(quoted from post at 20:04:05 05/10/18) If it has the two spool valve on top of the lift cover, the LEFT lever needs to be locked back for three point use.
It’s locked back. Used to work fine.
