MF 35 Deluxe
Ted Cole
My MF 35 is running good when not under a load such as bush hoging. When in tall grass it seems to just power down until i have to clutch it. It does not have any pick up to keep on cutting. HELP!!!!
How big is your 'hog? Is it adjusted right? (Level from side to side and the front end lower by about an inch than the back?) Are you using a suitable gear.
Assuming you have gas engine, a 6-7 ft 'hog and it's adjusted right and the gear is correct, do you have a FAT, BLUISH-WHITE SPARK, ~1/4" long and the color of lightning? If you don't you need to find out why( point s burned or misdjusted or worn, bad condensor, poor wiring connections, bad coil, bad key switch, etc)Is the timing correct and the advance working correctly and the correct firing order.
If all that is OK then try increasing the power jet adjustment( the big screw) on the carb. Turn it out 1/8 turn at a time and see if that improves the situation. Do that a couple of times and check the resuts. Check for adequate fuel delivery by holding a suitable container under the carb and removing the big plug under the fuel bowl. Fuels should come out CONTINUOSLY like a cow peein' on flat rock ! IF IT DOESN'T, CHECK THE SCREEN IN THE FUEL INLET ELBOW OF THE CARB AND THE ONE IN THE SEDIMENT BOWL. ALSO CHECK TO MAKE SURE THE VENT IN THE GAS CAP IS OPEN. If they are OK remove the tank valve and make sure that it is not clogged. If that is OK check for air leaks around the carb metering section ( throttle shaft, carb to manidold connection, intake manifold to cylinder head connection, cracked intake manifold) that is causing the mixture to lean out.
Sytematicall do these checks and idf you change anything restart and check to see if the change ixed the problem . If you do these checks sytematically in the order I have lsited them, you'll find the problem.
WOW!!! thanks for all the suggestions on how to fix my problem. I will try your suggestions this weekend and see if it helps. I was thinking around the govner as the problem. Thanks Again!!!
