mirthfuldragon
I have a 1960 (per model number) Massey 35 I purchased several months ago; the story I got is that it was pulled from a tree row, got running, and then I bought it running. Alternator is a GM-style 1 wire; battery is 12v, negative ground. I replaced all the gauges and wiring. From what I can find, it should have always been a 12v negative ground system.
The starter was giving me fits and wanted to be tapped with a hammer to spin over. I took it to a well-regarded local alternator/starter shop, and $90 later, it was working fine. I started it <20 times, did some work with it, and now it's back up to its old tricks, and won't spin over at all, taps or no taps. I bench-tested it with an old-school battery charger and no joy - no spin, nothing.
The starter itself has the long case of the 6v starter, 181541M91 per the manual. I believe it should be a 182454M91 12v starter.
Everything I've read says there's no issues running a 6v starter on 12v.
The shop said it was basically new inside, and looked fine, just that there was some corrosion on the brushes and it was sticking.
Am I missing anything here? "New" starter prices seem to run from $140 to $500+.
I'm going to take it back to the shop and see why they say, of course, but wondering if I shouldn't just buy a "new" 6v, since it will probably be cheaper (unfortunately) than rebuilding the current one. Or just buy a 12v.
