MF 35 with 2 bottom International 16 inch plow question
Can I run a International 420 two bottom plow with my Massey Ferguson 35 deluxe tractor or am I being too optimistic? Do I have enough tractor for this set up?. 16 inch bottoms with coltours. See photo
The ground is old pasture land that was farmed years ago but hasn't been plowed in 30 to 40 years.
What sort of problems or adjustments am I going to run into.
Thanks to all the experienced guys out there.
I would say you can pull it. Maybe not as deep as you would like if very hard. I pull
3-12's with TO 35. Be cutting same with 2-16's.Just set plow right is main thing.
We always pulled a 3 bottom ford three point 3 x 14 3 gear, low range Engine at STD PTO RPM...Engine at 1750 RPM
Sod...tough pulling...
Neighbor pulled the same plow...MF 50 ....same Transmission as our MF 35 X...he had a gas Continental...
Stubble, ...1 st gear High range...we had to throttle back......often puled one section of Diamond Harrow:
MF FE 35 X 3 cylinder Perkins diesel....44 HP....differential lock..
Bob...
