Anonymous-0
Help Please
Have purchased a MF35 complete with front end loader. Purchased seperatly a 6' 3PH blade. Can't have the blade on the 3PH hitch when using the loader as blade falls to ground. Why won't the blade stay in the up position so I can use the loader. The loader stays up so I can use the blade.
Any help will be greatly appreciated.
In order to answer your question, it would be helpful to know how the loader hydraulics are plumbed into the tractor. Are you able to post a picture?
If the loader runs off of the 3 pt. hydraulics the blade will creep down. I have the same problem on my 135. Most MF tractors 3 pt. arms creep down. Dave
You have a different arrangement than I have ever seen. I can tell you that there is no pressure on that port of the tractor unless the 3ph lever is higher than the corresponding position of the 3ph.
