(quoted from post at 05:33:21 01/02/15) I used a front pump on the PTO like that for the same reason. It had a large [ about 10" or 12" sprocket ] on the PTO with a chain to another small sprocket on the pump. I had it done at a shop so i don't know what ratio they had to come up with to make it work. It was used for a few years but after a while the chain and sprockets wore out and had to be lubed ofter. So i bought a "Prince" PTO pump and that's what is on it now. They work well until you need to use the PTO for something else. I fixed mine with easy off hose connections , about 5 min removal time . I then just raise the bucket up about 2 feet of the ground and remove the pump so i can hook up the "Brush hog" .
Correction , i raise the front of the loader up before i remove the pump. Then i just don't touch the control levers on the loader so it will stay up.
