mf 65 power steering cylinder.
tgrist
I have all the bolts out now how do I get the pin out? do I have to take the whole steering mechanism that drives the tie rods?
Loosen the pin by tapping a small screwdriver in EACH groove at casting end where the lock bolts go through. DON'T get carried away or the ears may break..
(quoted from post at 16:50:39 05/05/21) https://apb.agcocorp.com/
Use the guest user to login in without a password
mf 65 is not in the list of tractors. I must be doing something wrong. I am not able to login as a guest
I just rebuilt mine on my mf50 looks the same but you will want to get it apart first, some use O-rings on the piston and others use steel piston rings that you order separately from the standard kit.
I already bought a kit that has the piston rings. Do I
need to remove The big triangular shaped stop at the
end of the Cylinder shaft because that pin doesnt
seem to want to move.
(quoted from post at 14:50:07 05/07/21) I already bought a kit that has the piston rings. Do I
Remove the lower sheet metal first, use a wedge and spread the clamps slightly the pin will drive down. There is a notch in the frame you have to turn the wheel left to line the pin up with the notch so you can drive it all the way out.
