Mf 74 plows
Just bought a 4 bottom 74 mf plows. Not sure what the exact term for this part is but its where your link arms hook to it. Didn't realize it had a class 1 on it. The pins aren't long enough to hook to it. Does anybody know where can buy a heavier made one with longer pins. Thanks
You could get a set of arm ends that have both 7/8 and 1 1/8 holes in the ball. Even with the sleeves the original shaft pins are not long enough. Best to replace the cross shaft with the larger pins if you can find one..
I saw a set of those set up that way at an auction this spring. I couldn't think of any category 1 tractors that would pull a 4-16 mounted in the soils we have here.
Where are you located? I may have one.
