MF 85 Hyd/transmission/power steering cap.
old
So #1 is there more then one drain plug for the hyd, transmission/power steering??
Then #2 have many quarts/gal does it take to refill??
The I-T manual says something like 46 quarts is that right?? That would eb around 12 gal of fluid
Thanks
Three drain plugs total, one under the PTO, one under the tool box, and one under the clutch pedal. Should take eleven gallons of Dexron ATF to fill the system.
ATF,??? This thing had what looked like one of the UTF oils in it?? So will running a UTF like the 303 fluid hurt any thing?? And since it has had that in it does one change to the ATF instead ofthe UTF
I bought a parts manual for my super 90 at tradebit.com for $10. They emailed me a file I had to down load and print off. Best $10 I ever spent.
Did you check the pump pressure valve. See the link below.
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=mf&th=144909
