(quoted from post at 18:34:29 11/02/22)
There are 2 mounts at the rear of the 1085 cab where it sits on the axle. The distance between them is the exact same as the distance between the fender mounts on my 165. I figured the biggest problem would be getting it to work with the massey industrial loader on my 165.
You guys figure that is in no way sensible?
Thanks,
Pete
(quoted from post at 18:21:31 11/02/22)
This cab also does not have a door or window on the left hand side. Is this normal?
(quoted from post at 20:11:14 11/02/22)
That is a solid overview, thank you. I'm getting 2 measurements shown here https://www.verysharp.ca/misc/cab.jpg
if it can sit between the footplate and top of the hood, and in my garage I'll see what I can do to make it work.
(quoted from post at 06:19:58 11/03/22) Going to be tough. I have seen 165s with cabs. I seem to remember, although my memory should not be trusted, that European 165s had a longer transmission section to accept a cab. Maybe just buy a nice 1085 or if your pocketbook is like mine, a heat Houser.
(quoted from post at 09:46:53 11/03/22) Do it and then post pictures please. Anything is possible with enough time, sweat and effort.
