MF1100 3 point hich
My Girlfriend owns a 1974 MF1100 and the pivot shaft where the lift arm is attached to the lower back of the tractor is broke. The hitch/drawbar assembly is some kind of convertible unit that has a latching mechanism that swings under the bottom of the tractor to change drawbar configuration. I am looking for a parts diagram and a replacement shaft. Any help would be greatly appreciated.
Thanks,
Ed
Massey Ferguson parts books are on line at agcopartsbooks.com. On the sign in page click on the guest user to get to the home page. Then use the search for your model on the home page. Posting your approximate location may get you better answers on places to check for the parts in your area.
Probably a 1964, as 1105 was built in 1974. Early 1100/1130 did use a heavy curved drawbar, I'm guessing you need pin 511 992 M1, bushing 511 993 M1, and 353 602 X1 bolt.
Sounds like the pressure control style hitch like this.
