Harryaroo
I had put this on the mf page... I have a 1975 MF 1100. Worked ok -- except for 3 pt hitch-- until last night. Can't get the lever next to the seat to engage so I can use the pto. Could it be hydraulic issue?
You MAY have lost the front PTO flywheel spline coupler, or the REAR coupler at the trans/diff split joint. When either fails the PTO input drive to the hydraulic charge pump drive is lost, which means no hydraulics either.
