MF1105 Warning/Hazard Flashers
old 1100
I think I have this figured out, but I would like confirmation. Im working through the wiring on an 1105 I bought a few months back. The work lights and flashers arent acting right.
How are the warning lights/flashers supposed to work? It seems to me that the lights at the top of the cab should flash, and the ones on the fender behind the main work lights are constantly on, correct?
If this isnt right can someone give a description of how the wiring should be? I have two green wires that come in before the flasher to power the bulb and one orange one after the flasher that runs up to the top of the cab. Fender lights constantly on and cab lights flashing is the only thing that makes sense.
(quoted from post at 21:16:28 03/27/22) If I remember correctly the rear work lights have a dim red mode when flashers are on.
As in they don't turn on and off with the flasher, just a solid dim red, right? Because that's how I have it figured. And the only way I can make it work.
Our 1135 is open station so it's different. But the rear worklight is a dim red when the flashers are on like Lugnuts mentioned. I know for the os fender flashers the flasher unit is inside the rear light housing. I don't have my ops manual handy to see a wiring diagram.
Yes, the cab tractors are the same as the os description
except the flashers are up top. The light in the back of
the work light housing is a tail light, should show up as a
low red through the work light.
If the red coating on the window of the work light has
faded it can be refreshed with nail polish.
Perfect! Thats what I needed to confirm. Thank you all for your responses, Ill have all the lighting working right soon.
Thanks again.
This post was edited by old 1100 on 03/28/2022 at 01:09 pm.
