Jeff_G
Looking for a spec on the clutch fingers for a 135 with the 6 speed and Cont 145 engine. Specifically the clearance between the PTO clutch adjusting screws and the pressure plate. Also the clearance for the release levers. Fitting a new clutch.
(reply to post at 12:44:Most do a bout 67 to 60 on worn or even slightly worn disc. .067 between the nut head, adjust by loosining the hold nut and turn the head nut and retighten after setting. Sel all fingers on the plate to the same lowest setting of the three. I need to have a pic of the Z145 MF 135 throttle linkage image and diagram showing the connections of the springs and rods if you have that. 15 07/18/20)
[/quote]ttps://forumphotos.yesterdaystractors.com/photos/mvphoto105587.jpg[/img]
Edit:
Floydferguson,
Now I guess I am not sure I answered the right question. I see now Jeff's post is about 3 years old. I am not sure if the Clutch information is what you were looking for or not.
This post was edited by Jim.ME on 05/12/2023 at 02:58 pm.
