I have a MF 165 Diesel running hot. I checked the temperature gauge with a thermometer and the readings are the same..
I realized the radiator was not getting circulation; So i replaced the thermostat and ran some radiator cleaner through the radiator to clean it out.
I still had the same issue. Since a circulation problem is normally a sign of a Plugged radiator; I replaced the radiator.
I still have the same issue. The only thing left is the Water Pump. But i have never had a water pump impeller go bad that wasn't leaking or had a bearing issue. Water pump seems fine.
When this whole thing started it was running fine and got hot under heavy use. Normally I would be a lose Fan Belt or a stuck thermostat.
Any one here have a similar issue with water pump
