MF165 Parts ID
Myowneq
Hi, Im looking for two parts for a MF 165 diesel. First part is the rubber plug for the flywheel timing hole.
The 2nd is the tubing that goes from the injector line leak off off to the filter. It has a ferrule on one side and a banjo fitting on the other.
Any help would be appreciated.
Thank you.
I believe the part number for the tubing is 514439m91...the plug should be 732902m1, subs up to part number 4226916m1...both available from Massey.
Hope this helps.
Wayne
I bought the line you speak of from Jacks small engine. Make sure you are sitting down when you check the price.
Oh yeah, sorry, forgot to reply. Those part numbers were correct. And youre not joking on price. Cheapest is $75. Im electing to take q chance on some compression fittings to try and rrpair what I have. Fitting is $5.
Shop I called said if fittings still in good shape, why not put a piece of rubber hose in the middle. Thats whats there and it worked for years. If compression dont work, rubber hose it is.
Thanks for the help.
I have attempted to make that line using steel brake line. The Ferrell end went well but I was unable to solder the bango fitting to the steel line. After watching a couple of iTunes vidios on using silver solder and getting the correct I will try again.
