mf165 transmission troubles
alecb
Tractor MF165,Perkins with multipower,heard a crack ,engine stalled out blowing snow ,now will only start with clutch pedal down ,tractor seems to bind up when you release the clutch.Nothing in clutch inspection cover ,removed top of transmission at gear shifts,nothing seems bound or broken,any ideas?
With the top off the transmission, verify it is in neutral and not in 2 gears at once. Also disengage the PTO. If the transmission is still locked up, something is wrong in the transmission.
