MF200 loader hydraulic question
james275
I have a MF 2200 Industrial (gas) with the MF200 loader. I am looking for the lift arm lower hydraulic fitting. it has a 90 degree bend with an o ring in a shoulder type fitting. The MF200 loader parts catalog shows the part number 705 780 M91. Are these still available? I have asked hydraulic hose builders and they have never seen it.
Also, what type of oil. It is separate from the normal oil in the crankcase. Looks to be transmission oil. Reddish orange in color.
Thanks for any help.
This post was edited by james275 on 05/28/2022 at 11:05 am.
Look on AGCO'S site, they may have the
right hose.
An ORB X NPT fitting should work. That's
what I did with my 100 loader. I set mine
up so most of my hoses are NPT and easy to
make. TSC, Surplus Center, or a hydraulic
shop has ORD adapters.
Someone had a thread on here a few months
ago identifying the fitting you picture.
Maybe on a Work Bull?
I missed your fluid question. The original
spec probably called for ATF, not uncommon
for hydraulic systems. I use ISO 46 in
mine. I have a Parker 16 series pump. The
fluid is determined by the pump, for the
most part.
As stated, original fluid was ATF. Use whatever fluid works with your pump.
I use the same oil in my loader as in the transmission/rear end and power steering- Traveler's brand UTF.
Keeps the number of fluids I need on hand to a minimum.
