Eazycheeze
Hello, so I have a few post about other issues of the same loader however I went to mount the loader frame onto the subframe which is mounted to the tractor and I get the RH side bolt in but the LH side doesnt line up too well and I cant get the bolt it. Depending what side of the mount you want too start I can get the bolt in one side of the mount through the loader mount but it never lines up with both sides as in pictures, I can see it looks slightly bent but when I bought this it was all together maybe I should have never separated the two.
Either my arm is slightly bent or this is a common issue?
Any ideas would be fantastic, as of now Im thinking of heating it up to red colour and bang it straight /twist it the other way but I dont want to degrade the steel strength.
Or plan b, hookup hydraulics and use the bucket tilt and arm lift to position the joint a different way.
Maybe theres a trick?
