I went to use my 202 this morning. Started fine. I always turn the lift lever off when I park this thing so PTO is not activated when I go to start the tractor. I put the PTO in gear to raise the box blade off the ground and it raised fine.
I then tried to put the PTO in neutral as I wouldn't be needing it. The lever felt like it shifted to neutral as it always did but the PTO was still in gear. I can move the lever back and forth with the clutch in but the PTO will not move out of gear. Of course it does not work when I step on the clutch. Just can't get it out of gear with the PTO lever.
Any Ideas?
Any Ideas?
