Eazycheeze
Hey guys I just bought a mf202 which has the plow attachment and mower and post auger and a snowblower anywho, its been sitting for years and managed too get it running. Cleaned carb thoroughly, opened and clean the sediment bowl and just finished cleaning fuel tank. Adjusted the clutch free play. Bit of this and that.
Anywho it needs complete fluid changes too be safe.
So far Ive cross referenced a oil filter Napa 1010 and a power steering filter napa 1653.
Im going to use 10w-30 for oil and use some for the air filter oil bath.
I got all the coolant needed too flush it.
Now for the questions.
For the fuel strainer mine is either missing the strainer or its inside the bowl as in picture. If it is I tried cleaning best I could not sure how else but spray brake clean back and forth and air. How would I know its plugged should it be a steady flow or lots of drips? Or is this just a sediment bowl and I should buy a strainer ?
Now for the other oils , Im confused by all the posts of type of fluids and specs and having a hard time finding local. What modern day as today fluids can I get nearby? Dont need fancy fluid just need proper fluid.
I know I need gl1 spec or green mineral apparently?
Need to know the fluids for
Diff / Power steering / hydraulic ( all the same fluid right)
Transmission ?
Ive read lots of posts and everyone says different stuff, different spec standard, I just need oil!!
Is there any other fluid missing? And how much do I need? I found a few different fluids amounts as well. My manual is in order so I have no clue.
Also for the transmission and air filter do I just clean and reuse? And is there a screen in the air filter I need too clean as well?
Any proper methods I should do.
Also the power steering works pretty good however is it normal too have resistance for a second as soon as you turn then it gets easy ?
As said I also adjusted clutch free play , as my gears grind a bit going into gear, does not slip. Just doesnt seem like the clutch is slowling the gears down, is this normal for some grind and if not can I adjust the clutch through abscess hatch somewhere?
Second last, my throttle handle had no effect on motor until half too full it actually does raise rpm. So I adjusted linkages for the travel too max at max on the pivot for carb and the min for complete idle. It was perfect but as soon as I hooked the spring up I know have idle to half on the handle which half is full throttle, is there proper procedure or is this common on these too have dead spots on throttle handle? I have a digital tachometer coming so I can aim for 450 rpm idle exactly and adjust linkages from there and carb.
Last but not least, tractor feels like it has no brakes. I see rod and linkages, and assuming its drums so it should have adjuster and access slot , I will attempt but can I tighten the brake rods and whats the free play I should have for brakes?
Thank you very much any 1 question answered is helpful!!
Transmission ?
