Black Flag Forge
So after a few years I'm back to rebuilding my 202 workbull. When I left off last I had replaced the 4 PS lines and one of the cylinders and also rebuilt the pump and fluid tank. I fired it up and was immediately hosed down with fluid spraying from the steering column. I had replaced a part or two if I remember correctly and had the plastic/nylon bearing showing and the steering wheel removed. I killed the power and left it set as 2020 started and my priorities changed.
I just got out today and figured maybe I swapped the feed and return lines from the pump, made sure they're as show in the manual and tried again. Just the turnover cranks were enough to start fluid burbling out of the column so I abandoned the project for help.
As far as I can tell the only thing that goes on the steering column under the wheel itself is a dust seal, a cap, and the rubber seal cover.. does this cap seal that much pressure and I dont have anything else wrong?
