MF202 waterpump
wildwilf
Hello
Has anyone ever seen this set up. I ordered a waterpump and the shaft if to small to press fit the collar that hold everything on.
or do I have to change the pulley as well
thanks
Wilf
Do you happen to have a diesel engine? I have a MF202 with the gas engine and the picture you see below is the old pump that I replaced. The new pump looked exactly like it. The shroud just slipped right onto the water pump. There was no pressing involved. I'm one of those guys that purchased the MF202 with the ID plate missing from the dash. So, I have no serial number. But, I did manage to find that the engine was manufactured in 1958 according to the ID plate on the engine.
I have a 63 with a gas engine. I don't know why the difference but the new pulley arrived today.
I have searched model after model of MF tractors and could find any that have the same fan setup as mine.
Just my luck I would get the oddball.
now I hope it is the same length when it is all back together
Thanks for the reply
This is a page from my parts manual. #32 is the pump and #33 is the shroud. I think when I ordered it I ordered the water pump assembly. The former pic is what I received. It did not come with the shroud. The old shroud fit it just fine. Sorry, I don't know anything about the parts you have pictured. It seems that my water pump assembly consists of #26 impeller on to #32 pulley with all parts in between. That's the first picture I posted
I don't have the that shroud. the shroud I have has the pulley attached.
got it all pressed together so in the morning I will see if it all fits
thanks again
Wilf
