MF203 brakes
Ilyak
Apologies if this is question is answered elsewhere.
I have just acquired an MF203 industrial tractor.
As far as I can tell there are inboard wet brakes and outboard dry brake options. I seem to have both but with the outboard ones not connected.
I've highlighted in red the link that seems to drive the outboard brakes, there's one each side.
Is there a part I can get to connect that also to the brake pedals.
The right brake is good, I like the right brake, it's a good right brake. The left brake not so much.
I have hilly ground so two good brakes would be helpful.
Without taking everything apart it seems if I could adjust the left brake and also connect the outboard brakes (I don't know if they work but they may do something) I'll probably be ok.
I'm in the UK so will need to get parts here.
Thanks again for any help.
I've tried multiple times to post and it accuses me of dubiousness so I'll try without picture if that helps. Sorry if that makes it hard to follow!
The problem is trying to post the picture. I tried to post it in reply and it objects.
If anyone knows anything about this problem (fixing brakes or posting pictures!) let me know. I can send the picture separately somehow.
(quoted from post at 03:55:05 06/19/20) The problem is trying to post the picture. I tried to post it in reply and it objects.
It won't let you post a picture because you only have two posts to your record. I forget how many posts you actually need but it's not too many, I think.
Hmmmm. My 1966 203 has inboard dry discs and my service manual only shows dry and wet discs. Possible my whole differential housing
has been swapped out?
(quoted from post at 09:47:19 06/20/20) They only have outboard drum brakes (no inboard disk brakes), the other pedal behind your right foot is for the differential lock.
Did the MF202 ever have a differential lock? Mine does not and I sure wish it did.
My mistake, the 203, and 205 diesels did have dry inboard disk brakes with outboard planetaries on the rear axles (still tired from working late last night).
