MF2500 Offroad Forklift
Wadegrover
Am new to this site. Not sure if this is the right place to look but looking for a used wheel hub for the steering tire part number 674 432 M91 for a MF2500 outdoor forklift and not sure where to find one. Any help would be greatly appreciated. Located in Central Wisconsin.
Thanks in advance.
Wade
715-323-0323
(quoted from post at 09:28:56 04/12/23) What's wrong with the hub? You could try Wenger's in South Eastern PA. Some parts are available from AGCO.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto152188.jpg>
AGCO
The bearings wore out the inner part of the hub where the inner race goes. Hoping to find a used one somewhere in Wisconsin. Would imagine very high cost to ship due to the weight.
Thanks for the tip.
Might try doing a little research on bearings. Might be able to find a thicker outside race then have a machine shop turn hub to fit.
(quoted from post at 19:03:54 04/12/23) Might try doing a little research on bearings. Might be able to find a thicker outside race then have a machine shop turn hub to fit.
A shop might be able to build it up (or put a sleeve in it) and bore it back to original. Might be worth a check as well.
This post was edited by Jim.ME on 04/12/2023 at 04:20 pm.
A machine shop would have no trouble
repairing it. You would need a way to
fixture it to keep the bores in line. I
would expect $1k here outside of
Philadelphia.
How worn-out is it? Do you have any way
to measure the bore and the cup? I don't
think I've ever had a cup eat a bore
before, usually the spindle gets trashed.
Is it possible you have the wrong cup or
the cup is smaller than tolerance (the
land of almost right)?
If it were me, I'd measure everything with
a micrometer. If that isn't possible, I'd
order both new cups from AGCO. If I still
didn't have an interference fit, I'd use
bearing retaining compound Loctite
makes one to fill up to 0.020 (620).
0.040 is a lot of wear in that bore. You
would have to make a reasonable guess as
to what the wear is, the retaining
compound for 0.020 may not work for
0.003. McMaster- Carr has a fair
selection.
I didn't see this for myself, but I
wouldn't be surprised if it is the wrong
cup. Good luck.
(quoted from post at 20:16:43 04/12/23) A machine shop would have no trouble
Philadelphia.
selection.
cup. Good luck.
Thank you for all of the advice. What started this all was the wheel bearings were so bad the wheel fell off the machine. The inner race was about impossible to get out from the damage to it. I do have a machine shop at my work and they are currently trying to put a bead of weld where the inner race goes and cut it back out to size. He did say he would have to build a centering cone to keep centered. Hopefully this will work.
Thanks again
