MF30 alternator wiring
StNick
I had the alternator burn up on my MF30 with the AD4-203 Perkins diesel motor and was wondering if anyone knows where the two wires attached to the connector at the top of the alternator go to? The wires came loose and I need to know which wire goes to which spade lug on the alternator, and what could happen if I hook them up backwards. Thanks!
(quoted from post at 14:11:53 02/24/21) I had the alternator burn up on my MF30 with the AD4-203 Perkins diesel motor and was wondering if anyone knows where the two wires attached to the connector at the top of the alternator go to? The wires came loose and I need to know which wire goes to which spade lug on the alternator, and what could happen if I hook them up backwards. Thanks!
You should be able to post pictures of the alternator and wires in question, that would help.
